2001 Sequoia Limited lift gate module...lock/unlock...window up and down
Timf1981
Minneapolis
This is my sisters Sequoia. 2001
So not a lot of specific history.
Rear door exterior handle is broken.
Lift gate was not op-enable. I managed to get it open. not fun...I did remove most everything from inside the lift gate and removed the entire latch mechanism.
I have a second latch mechanism. Both have working lock actuators if i jump them with 12v.
Both mechanisms will show an open and closed ohm readings on the sensor depending on the position of the latch.
The window brake was not installed when i opened up the back of the lift gate.
The black lock cylinder was in the halfway position when i first got things opened up.
REAR WINDOW...
Window motor will go up and down if i directly jump it with 12v.
It will go down with the switch on he dash. But not up, even with tailgate shut.
We do not have a key fob.
I do have an Autel car scanner. The lift gate would not respond to direct commands to unlock or lock. And it would not respond to window open and close demands.
Questions....
i have read about possible wires breaking where they come out of the vehicle. There is a big wire connector halfway down the lift gate. Does anyone have a wiring diagram for this so i can look for a lock and window signal before it gets down to the module ?
My best guess Is a module failure. . But this part is the least readily available. I do have a 2005 complete lift gate. But the wires going into the connector are very different .
HELP....
Questions....
HELP....
Here is the module on an '04. Not sure if its applicable to the '01 but if I check tomorrow and see its different ill repost.
I believe (B) = B10 is the connector going into the module from the body wiring harness(coming from the car into the liftgate)
I can't post the entire diagram as its multiple pages and I can't even show the entire page at a size that's discernable so I traced most the lines and wrote it down.
-Pin 1 White w/ Red trace I believe is power as it comes from a junction that feeds multiple modules, originates from ECU-B 7.5 amp
-Pin 2 Light blue(?) w/ White trace comes from PWR NO.5 30 amp, assuming this is window motor/lock load power source.
-Pin 3 White w/ Black trace is ground
-Pin 4 Black w/ Red trace is labeled SIG, Originates from ECU IG and feeds into a junction connector which then feeds into multiple modules also labeled SIG. I THINK this is on/off wake up signal voltage.
-Pin 5 Light Green w/ Red trace comes from the Body ECU but passes through the instrument cluster / speedometer
-Pin 6 Black is labeled MPX1 and comes from the Front passenger door module. My guess is this is the data line. I am assuming this is early CAN BUS communications because there is no other clear signal wires coming from any other modules.
(A) B11 looks to be the connector for the lift gate harness(locks, windows, sensors etc) so not really applicable to a break at the hinge
Unfortunately you'll probably have to find the front passenger door module OR the junction connector, disconnect both sides of the harness (pin 6 on back door module and pin 10 on front passenger door module) and check for continuity. As well as check for power on pin 1/2/4 and ground on pin 3.
Not sure where the grounds physically located for this circuit but I've seen a few situations on other vehicles where rust was prevalent and components grounded to the liftgate itself weren't getting chassis ground through the hinges of the liftgate. If you do have rust, maybe attached a ground wire to a bolt on the liftgate and then to the body and see if the module wakes up.
LMK if u want me to trace any other wires or need specific diagrams for an individual wire. I have the back of my rig all torn apart at the moment, ill see if i can find the junction connector too.
Good news! Pull down the interior panel with the rear dome light and 3rd row center seat belt and there are two electrical connectors on the left/drivers side going down into the drivers D pillar. These look to be the sub harness for the LiftGate. You can disconnect them and the bulk connector on the LiftGate and continuity test the harness going through the LiftGate hinge.
