IDLE stutter
I would start with throttle body air flow. Inspect/replace the engine air filter. Inspect the throttle body and vacuum lines replacing any cracked lines and clean the throttle body.
I think it’s less likely that your alternator is failing at low rpm but you may want to confirm 13.3V or higher at the battery connections when idling.
