I made custom amber lights for the OEM grille
Preisler Products
Boulder, CO
I really wanted to get a set of amber grille lights like everyone gets with their TRD replica bumpers but didn't want to break the bank. Looked around and no one makes them for the OEM grille, so I put my CAD skills to use and designed a custom adapter to make it work. Now I've put together a full install kit so you can get them too.
Kit includes four (4) amber LED grille lights in sealed polycarbonate housings with custom nylon mounts that fit the OEM grille on the 2nd (and 1st) generation of Toyota Sequoias.
The custom mounts are made from laser sintered nylon (3201 PA-F) with a heat deflection of 295°F and were designed and tested in Boulder, CO.
The wiring harness is plug-and-play and includes a pre-crimped, Add-a-Circuit fuse holder that connects directly into your engine bay fuse box, a 5 Amp low-profile fuse to protect the lights from electrical surge, and assorted zip-ties for an easy and professional looking installation.
Includes detailed installation instructions with photos that show how to attach the mounts, route the wires, and make the final electrical connections.
Looks pretty cool! Thank you for sharing!
Thank you! I sent out the first batch of lights the other day and included a request for install photos. Hopefully I'll follow be able to follow up with some cool shots in a few weeks.
