On the highway I hear a faint sound of air at the front driver’s door or window. Anyone else have this? That’s annoying and good luck has been the only answer for it.
My first thought was that the window wasn’t sealing correctly, now that you mention the a/c I’ll turn the system off and troubleshoot from there. Thanks for the starting tip I’ll be back!!
I’m dealing with the same issue. I did notice the right rear arm rest compartment blows air out substantially, causing a constant loud noise. Still trying to figure out the leak as well, as it sound like it’s coming from the sunroof area. The rear doors seem to pick up road noise as well.
I haven’t been able to find the exact location of the air movement , but if I press my elbow hard against the middle of the driver’s window that air noise stops. Very evident on a not so smooth highway. Service Department said, “That’s annoying” and in other words, good luck.. Need someone’s opinion as to how to tackle this with the dealership.
