2002sequoia1
The person that sold it to me said it needs the SAIS what are some things i can do to make sure that really what it is.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Thanks I really appreciate it.the SAIS system isn’t on 2002 models it was firsrt used in 2005. Per chat gpt The 2002 Sequoia uses the non-VVT-i 4.7L 2UZ-FE. Its emissions equipment includes things such as EGR, EVAP, oxygen sensors, catalytic converters, etc., but it does not have the electrically driven secondary-air pump and associated air-switching valves found on the later system. The SAIS system apparently quick heats the catalytic converter.
So, basically drive, look, listen, and pull dash codes. Good luck. I hope it runs well for you.
