Hello fellow Sequoias
bassrvr1
Williamsburg
New to the group and in desperate need of some advice. Had horn issue and replaced clock spring. No horn. Found out I could tap off the ground of the cruise control to the steering wheel and voila….horn. But now I have an airbag light I cannot get rid of.
Thinking I could just order another clock spring on eBay, I looked and found many that said they fit 2003 Sequoia Limited. I ordered a few since they were cheap enough ($25-40) Almost all of them had some variation of plugs, blades, airbag connection. I even ordered from ToyotaPartsDeal.com. ($252) Provided my vin # and still received something different than what I had. Then to make things worse they refused to take it back because it was ‘electrical’. I could not even install it.
How do you avoid getting something different than what you need?
Item on left is oem, on the right what ToyotaPartsDeal.com sent
Hello @bassrvr1 welcome to the site! Wish I could help you on your post but hopefully someone else chimes in.
Update….brought it into the shop. The issue of getting the correct clock spring continues. What I finally got and thought it was an exact replacement had one difference. Pins going into the airbag had 2 where my original had 4…..ugh. Putting some resistors in to do a go around.
Let you know how it works out.
Note: this whole mess came about because of no horn. When I grounded a wire from the cruise control to the wheel, I got a horn, but I also ended up with airbag light. So I drilled down even further based in some Youtube vids, that indicated bearings may be rusty and need cleaned and lubricated in lithium. Apparently the rusted bearings could prevent proper grounding. And boy were they rusted so I did cleaned them DeoxIT and applied lithium grease.
Reassembled everything. And still airbag light!! Plus I must not have assembled it correctly since when I turn hard car shudders. Sometime is off in the steering wheel sensor. Mechanic thinks he knows what I did and will address it.
Now I find out Virginia law was changed in December an airbag is no longer included in inspections.
Shoot me
Its kind of important to keep the clock spring indexed when installing/working on it. Tires and wheel need to be straight, pull the plastic clip only once the unit is installed on the steering shaft.
If you take it off, you need to tape or zip tie the clock spring so it cant rotate. If its off center when installed the traction system will be pretty confused as to the steering angle and it could even break the cable if its indexed far enough off center.
