2002 Limited 4wd - Back up Camera
Cullen
Dallas
I am planning to tackle a back up camera and head unit this weekend. I am trying to avoid cutting factory harness at the reverse light. Are there are other power sources that are triggered in reverse? I have seen some people discuss a extra pin on a harness behind the dash but I have not been able to confirm. Open to any ideas.
I am planning to tackle a back up camera and head unit this weekend. I am trying to avoid cutting factory harness at the reverse light. Are there are other power sources that are triggered in reverse? I have seen some people discuss an extra pin on a harness behind the dash but I have not been able to confirm. Open to any ideas.
I took the easy route and installed a wolf box (front and rear cameras) set up. That was an easier option for me as I also didn’t want to splice wires.
A lot of cameras can be triggered off the reverse lights circuit. If its power signal it needs just run the trigger wire down the D pillar, pull out your tail light and splice the wire into the reverse light circuit, power side.
